Prisistatysiu ir as, ypac kai dabar turiu kuo pasigirti. Taigi dabar vairuoju MR2 GT (1991m LHD) ir MR2 Turbo (gime budamas N/A 1992m RHD, perdarytas i rev3 3S-GTE)
Dabar apie kiekviena atskirai.
Apie MR2 GT :
paprastas 3S-GE stock variklis (o ka ten is jo isbursi..)
Fast Road clutch (up to 320bhp)
HSD coilovers
Delphi stabilizatoriaus traukes
Poliuretanines stabilizatoriaus ivores
O dabar apie tik ka isigyta zaisliuka (cia tai jau rimciau
Ratus suka pilnai per nauja surinktas rev3 3S-GTE, kuris pagal Dyno suka:
Maximum Power – Wheels 271.6 bhp @ 6,063 rpm
Maximum Power – Engine 312.1 bhp @ 6,063 rpm
Maximum Torque 293,7lbft (396,8 nm) @ 4694 rpm
Kaip sakiau variklis naujai surinktas:
Rev3 Block
3S-GTE 86.00mm JE forged piston kit
Carillo 3S-GTE rod kit 5.433
CT26 stage 3 turbo fully ported, blueprinted & balanced to racing standarts, 48mm compressor wheel with large diameter steel shaft, 360 degree thrust bearing, 12psi actuator
Twin plate 700 series rally clutch
700 flywheel
Release bearing carrier
700 release bearing, low load type
700 bolt kit
rev3 oil pump
TRD low temp thermostat
Cosmo fuel regulator
ARP main and head stud kit
TRD iridium plugs
SAMCO RED hoses
HKS steel head gasket
ST205 dump pipe
Revision 6 Radtec Chargecooler
New Genuine Toyota 3S-GTE crankshaft and bearings
HKS blow-off valve
Magnecor zvakiu laidai
Link G3 ECU
MR2 Turbo Mongoose Exhaust
Magnetic drain plug
Na ir kalnas visokiu mielaciu tokiu kaip naujas skriejikas, davikliai t.t ir panasiai
Vaziuokle:
R17 su Goodyear Eagle F1
Koni top adjustable shocks
Fensport Racing F1 progressive spring kit
Stainless braided competition brake lines
DOT 5.1 brake fluid
New handbrake cables
Reconditioned calipers
New Master and Slave cylinder
Grooved and Drilled brake discs
Carbotech Panther Plus brake pads
Exterior:
Modifikuotas priekinis bamperis
APR Performance GTC – 300 Carbon Rear Wing
Interior:
Persiutas salonas i oda,
Boost gauge
Oil pressure gauge
Gali but kad kazka praleidau, nes yra kalnas tai patvirtinanciu popieriu, bet kadangi bandziau kategorijom surasyt, tai visko gali but.
www.powerlab.cz
