Pamegink klema akumo nuimti ir palaukti bent 10 sec.
Edit:
Siaip didesne pauze tarp klaidu turetu buti, nei, kad tu pavaizdavai... Jei 11 ir 31 tai:
Code 11
Short to ground in circuit between center air bag sensor and
either air bag; faulty air bag; short to ground in circuit between
front air bag sensor and center air bag sensor; faulty front air bag
sensor; +S and -S circuits between front air bag sensor and center air
bag sensor are shorted together; faulty spiral cable; faulty center
air bag sensor.
Code 31
Faulty center air bag sensor.
CLEARING CODES
1) At DLC, connect a jumper wire to terminal Tc. See Figs. 11
and 12. Connect another jumper wire to terminal AB. Turn ignition
switch to ACC or ON position. Wait about 6 seconds.
2) Starting with terminal Tc, apply body ground alternately
to terminal Tc and terminal AB twice each, in cycles of 1/2 to 1 1/2
seconds (sequence is: Tc, AB, Tc, A
. Finally, keep applying body
ground to terminal Tc until air bag warning light flashes quickly,
indicating codes are cleared.
NOTE: When alternately connecting jumper probes to terminals,
simultaneously release one probe from one terminal while
connecting other probe to other terminal. If time interval
between probings exceeds 0.2 second, codes will not clear.
Bet kodel taip sudetingai trinami klaidu kodai, tai man nedaeina...
Saltinis
